is SPF safe to put in Audi
I have an 97 audi a4 and I buy this SPF stuff to clean the engine, you put it in when you gas up, I don't know if it's ok for german cars? And I use 93 octane is that ok too? Or should I stick to the regular... Thanks for the help.
Yep forget the low grade stuff and use 93.
Your cleaner stuff, I would imagine its like seafoam you can use it in your fuel and oil? Unless it states only one or the other. For me I would just use seafoam and I have also used lucas products. I just think the oil additive is garbage and I would not suggest it except for seafoam. If you do put it in the oil drive it for like 100 miles and change your oil out.
bmwtoaudi
12-09-2006 03:42 PM
