speedometer works but car doesnt move
hey guys,
i'm trying to help a friend out with his audi. there is a relativley new clutch in it and the trans. can shift through all the gears, but if you let your foot off the clutch (in gear or not) the car doesnt move. the speedometer works, so the problem lies after the speedo sensor. its got AWD andi dont think its a busted cv since the car would still move if a cv was broken. any ideas? its a awd, 5 spd, quattro (dont know the # of cyls.) .
thanks
thanks
RE: speedometer works but car doesnt move
fairly new clutch doesn't mean anything and a semi burnt up clutch might still let the car start
i broke all the teeth off my clutch on my s-10 doing a hard shift durring a burnout....... and you could press it in to get the truck to start, but when you let it out, you would hear a horrible grinding noise and the truck would die, cause there were no teeth to catch with..... not saying that is his problem, but you guys might be looking at a new clutch, if so get a beefier clutch or get an auto, cause the driver can't drive a standard tranny
i must say this is a very weird problem. the speed sensor is incorporated into the abs sensor which is on the hub. are you trying to say the tach works? the install of the clutch may have gone wrong somewhere. also check your brakes. they may have seized up or something.
i thought of something else... he could have cracked the transmissioncasing and broken off teeth on some gears. thats what happened to my caralthough my speedo wasnt working either so i dunno
ORIGINAL: hiwords
Bori2014Sky
09-13-2014 11:58 AM
Sline4.2
04-03-2012 10:02 PM
ssingh
03-14-2011 03:08 PM
