Speedo Clocks Change
Hi All. I will be changing my full set off clocks on my 2.8 auto in the next couple of weeks due to fault in the display. I am told that I need to reprogramme the clocks into the car else the car will not even start. Can this be done with VCDS-Lite or do I need something a bit more substantial. Any help appreciated.
Thanks all
Thanks all
That's a decent price for a repair... I'm guessing you found a donor cluster as a full swap. The mileage reading cannot be altered as well. I also assume you are speaking of calibrating the speedometer. The car should still run, it just won't give you proper reading. You may have an immobilizer considering the region you're in.
Ross-Tech: VAG-COM: Immobilizer 2 ECU Swapping
if that doesn't work a few people can do it the hard way for a fee, i think the deals charges 200 and you have to buy new keys, but people on the forums usually do it for 50.
vw754
06-17-2006 12:34 PM
