speed increase
speed increase
im looking at a 1997 audi a4 quattro 1.8t. It has borla exhaust, hugo ignition module, turbo blow off valve, and a cold air intake. It also has sport suspension springs. Will this increase the speed of the car any? Or does it just make it run better?
RE: speed increase
thease things will increase horsepower, but as far as top end speed, unless you have a chip that removes the govner you will be limited,
think of you engine as a giant air pump the quicker you get the air in and out the better it will run
RE: speed increase
ORIGINAL: rlubbers
im looking at a 1997 audi a4 quattro 1.8t. It has borla exhaust(helps some... not a ton), hugo ignition module(wtf is this?), turbo blow off valve(sounds like a cheap ebay bov, get a forge 006/7 or forge 004), and a cold air intake(won't help any really other than make the bov louder). It also has sport suspension springs(maybe better handeling, which will make you faster in the turns). Will this increase the speed of the car any? Or does it just make it run better?
