Speakers/ Head unit
I see. Ok There are no bose logos on the speaker grills. No bose on the radio when I turn it on. Also its a 1999.5 and doesnt even have a cd player. Only cassete and radio. So Im gonna assume its not bose?
Edit:
I believe the non-bose have 4" in the front. Is there like an adapter so I can put 5 1/4" in the front instead of 4 "? If not can I use these?
http://www.ebay.com/itm/ALPINE-TYPE-...item41657bcade
Is there a problem with switching out components to 2 way like those? I couldnt find any 4 " component only 2 way. If I can use those speakers then do I have to disconnect the tweeters or can I keep the tweeters and also run those 4" 2 way?
Edit:
There's 2 wires(a negative and positive) in each speaker. You can leave the tweeters the way they are and should still work.
I'm sure you'd come up with something to mount the speakers. I had no plan prior to buying the replacement speakers. I took it off then just came up with the idea on the spot. Dont forget to consider the depth of the speakers....
#19
it took me 5 minutes. i built a wood ring
and look harder next time
http://www.google.com/search?client=...w=1440&bih=678
#20
I see that but none of those are brands i know. I want like an alpine or jl speaker. But they only make 2 way coaxial they dont have just a seperate mudrange speaker. But maybe ill grab those power acoustics cuz theyre so cheap.
