spark fuel but no start
so i did a motor swap in my car it cranks i have spark and it gets fuel but doesn't want to start have not run a compression check yet but hope to god it is good if the compression is good what can i try o and it is a 01 old engine was awm new is 2000 aeb
so this is what i came up with my compression is fine but i am coming up with code p0322 which has to do with the speed sensor which makes sense why it wont start. i tested the ground wire and it is getting a good ground so im thinking that somewhere in swap it got damaged right
I dont know which car and code which engine came from because your next to impossible to understand, but I'm assuming the bottom ends are both 06a blocks or else the sensors just wouldnt match up. BUT, as far as I know, all AEB cars use Ignition Control Modules (ICM's), and the newer ones do not. They are both coil on plug setups, but the newer ecu's have ignition control built in. Most likely your problem.
TCBAudifx
11-24-2014 01:27 PM
Vict0ar
04-03-2014 08:38 PM
