Snow stall
Snow stall
After driving through some really deep snow my car wouldn't idle it just kept stalling. It did this for about a minute and then it worked fine again. But it did happen multiple times throughout the day only in short periods. I assume that I sucked in snow somewhere. What do you think?
Probably. I remember last winter one of our members, achTTung, posted up that the deep snow he was driving through melted when it hit his rad and engine and all the water caused his serp belt to slip off. Water causes problems.
It keeps randomly stalling out, I checked my air filter and it looked pretty ugly could this cause it? Also under full boost my turbo sounds way louder then before, like someone slurping through a straw. It is also hesitant on acceleration. I'm going crazy.
Sounds like you may need to pull the turbo to check it out. How many miles on your car and has your turbo ever been rebuilt or replaced?
Your air filter, if dirty, will need cleaning either way, so go ahead and try it first. I'd also suggest cleaning your MAF sensor.
You're getting toward that time where the unreliable K03 would have to be rebuilt... I'd pull it.
Edit: Not sure why this put my post before yours but it's a response to you saying it was never rebuilt/replaced.
