Smoke from under the hood
All right, I've got some thin, whispy white smoke coming from the front left corner of my engine. I replaced my valve cover gasket thinking that might have been it, but that didn't do it. I'm not losing coolant, it has a somewhat metallic smell to it, and I don't seem to be burning any oil (I'm never low when I change it. It could be a really slow oil leak (which is why I assumed the gasket) and I know it's not a crack in the block or anything because my coolant is clean and now I'm stumped. I seem to notice it more if I have the heat or AC on (like when the AC has been running with the defrost so any ideas?
RE: Smoke from under the hood
you don't need to loose that much coolant to get that whispy smoke....my guess would be that you are loosin a lil bit of coolant....
though I have never thought of coolant as metalic...the only two metalic smells I have smelled in a car are breaks and clutch....I have never had a clutch smoke, but I have had breaks smoke, just not through the corner of my engine...
my guess is coolant...gl!
