Side Airbag Igniter - passenger side (N200)
The airbag light is on since a while.
VAGcom shows the following error code:
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 M
Component: Airbag 7 Audi 0502
Coding: 00104
Shop #: WSC 06435
VCID: 4081B4DD6AF1
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
32-00 - Resistance too High
The 'measuring block" log reads:
; VCDS Label File
; Audi A4 (8D)
; Component: J234 - Airbag (#15): AIRBAG7
; P/N: 8D0-959-655-???
; includes measuring blocks, coding and adaptation
; This file is part of a redirection package,
; make sure you have all of the following files.
; 8D-15.LBL
; 8D0-959-655-AI7.LBL
; 8D0-959-655-AI8.LBL
; created on 18/Dec/2006 by Sebastian Stange (Sebastian@Ross-Tech.com)
; last modification: 30/jun/2008
; requires VCDS 805.0 or newer
; measuring blocks
001,0,Ignitiers I (Front Airbags && Front Belt Tensioners)
001,1,Airbag,Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,2,Airbag,Passenger Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,3,Belt Tensioner,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
001,4,Belt Tensioner,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,0,Ignitiers II (Rear Belt Tensioners)
002,1,Belt Tensioner,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,2,Belt Tensioner,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
002,3,Belt Tensioner,Rear Center,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
003,0,Voltage && Seat. Occupation && Belt Inquiry I (Front)
003,1,Voltage Supply,,Specification: Correct
003,2,Occupied Seat,Sensor Pass. Side,Display Range: child/child seat/light adult/heavy adult/occupied/not occupied/not installed
003,3,Belt Inquiry,Front Driver Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
003,4,Belt Inquiry,Front Pass. Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,0,Belt Inquiry II (Rear)
004,1,Belt Inquiry,Rear Driver Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,2,Belt Inquiry,Rear Pass. Side,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
004,3,Belt Inquiry,Rear Center,Specification: Belt Yes/Belt No\nDisplay Range: Too Low/Too High/Trig.Ground/Trig.Plus/Belt Yes/Belt No
005,0,Igniters III (Side Airbags)
005,1,Side Airbag,Front Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
005,2,Side Airbag,Front Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
005,3,Side Airbag,Rear Driver Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
005,4,Side Airbag,Rear Pass. Side,Specification: Correct\nDisplay Range: Correct/Too Low/Too High/Trig.Ground/Trig.Plus
006,0,Seat Occupation (Rear)
006,1,Seat Occupation,Rear Driver Side,Display Range: Too High
006,2,Seat Occupation,Rear Pass. Side,Display Range: Too High
; coding
C00,Airbag 7 (J234) Coding
C01,00?0x: Side Airbags
C02,0 = Front Side Airbags not installed
C03,1 = Front Side Airbags installed
C04,
C05,00x0?: Rear Belt Tensioner
C06,2 = Rear Belt Tensioners not installed
C07,4 = 2 Rear Belt Tensioners installed
C08,6 = 3 Rear Belt Tensioners installed
; adaptation
A001,0,Front Passenger Airbag Deactivation
A001,1,Front Passenger,Airbag
A001,2,Current Status
A001,5,Front Passenger Airbag Deactivation
A001,6,0 = Airbag Enabled (Standard)
A001,7,1 = Airbag Disabled
A001,8,
A001,9,Note: Refer to Service Manual!
When wiggling the middle of the 3 connectors under the passenger seat, I can get one of the values to switch between "too high" and ok (or so).
Measuring Block screen shots:
Coding: 00104
Shop #: WSC 06435
VCID: 4081B4DD6AF1
1 Fault Found:
; VCDS Label File
; Audi A4 (8D)
; 8D-15.LBL
; measuring blocks
; coding
C04,
; adaptation
A001,8,
You're gonna notice that it only shows up when you have passenger's in the back seat, its a common code to come up on B5's. It usually happens when folks push their legs against the back seat or under it. There really isn't any fix for it.
I had this pop on me this weekend. Is there a fix so that I can clear the code/light?
vtraudt when you wiggle the wire will it not "stay" wiggled?
auditech79 when I noticed the light I didn't have any passengers at all. I did however dump the clutch a little hard.
Actually theres a fix for this what is going on is the wire is getting loose so what u do is, put a tie wrap around the airbag connector and than clear the codes and no more codes =]]
i believe the how to is here
http://audidiy.com/
http://audidiy.com/
More likely, faulty wiring or connector.
http://audidiy.com/
http://audidiy.com/
http://forums.vwvortex.com/zerothread?id=2815467
chawkinson
04-28-2017 08:49 PM
mr_indomitable
04-24-2009 12:06 AM
