Short shifter recommendation?
Old 10-31-2009, 11:47 AM
codymack43's Avatar
Originally Posted by AudiTurbo
What if we have the push down reverse? Have a link for that?
thanks
Yeah thats something i was concerned about as well. With the jhm it takes out the push reverse, and i've heard the shifting takes a while to get used to. Will this have push reverse? Cuz i like having that...
Old 10-31-2009, 12:20 PM
A4Cragman's Avatar
Yes, the kit retains the push down. The particular kit I got came with a new spring that had a higher spring coefficient so it takes a little more force to push down, which could have been what it was like when new. The instructions CC mentioned include details for installing it on every configuration possible- with push down, without push down, 5 speed, 6 speed, 5 with R in the bottom right, 5 with R in top left etc etc so you'll be set. Best advice I can give you is to make sure you have a 3/8" drive ratchet with an 8" extension (Unless you're plan on pulling apart your whole center console to do the install) and ABSOLUTELY get the allen key in socket form. I believe its a 6mm but could be wrong, but you will hate life something fierce if you try to break the linkage bolts with just an allen key. Getting the allen bit attached to a socket is about 5-6 bucks at sears and will let you break that bolt in about 3 seconds flat. I learned the hard way that that bolt, covered in 12 year old loctite DOES. NOT. BUDGE. by way of a mere allen key. Other than that, the install is pretty straightforward and with the right tools, should only take you an hour tops.
Old 10-31-2009, 12:22 PM
codymack43's Avatar
Yeah I have access to all the tools i'll need. I was just worried about that push reverse. I have the 5-sp with R in the bottom right.. i didnt know there were different setups
Old 10-31-2009, 03:04 PM
A4Cragman's Avatar
Yea, the kit is designed to work with any B5, so that covers any car from 1996-2001, all the A4's, the S4, and the A6 as well. The S4 has 6 speed with R in top left, and I think with the '96's push down was an option so there are some variations, but the kit includes every piece to adapt to the setup you have, which means there will be a few components not used, and the instructions are detailed as well for each setup so you should be good.
Old 10-31-2009, 03:48 PM
codymack43's Avatar
ok cool, thanks for all of your help!
I bid on the one i was looking at.. if i get out bid i'll prob just buy it now.
Old 10-31-2009, 08:29 PM
codymack43's Avatar
Just won the auction... shifter should be here in a couple days. I'm sure I can get get an install off here right? Should I post pix of install?
Old 10-31-2009, 08:45 PM
A4Cragman's Avatar
Nice, congrats. Hit up aledelic42, I think he still has the install instructions in a PDF hosted on mediashare or something like that.
  #18
Old 10-31-2009, 08:54 PM
codymack43's Avatar
I found the install instructions in the search. I'll post pix when I get to work
jibberjive
02-24-2009 12:57 AM
jibberjive
01-09-2009 09:16 AM
jinyya05
08-17-2007 07:03 PM
SideShowBobA4
02-18-2006 03:25 AM
jja2.8
06-14-2005 04:27 PM
Quick Reply: Short shifter recommendation?
