Short shifter?
Old 10-14-2010, 07:41 PM
lolo22's Avatar
Default Short shifter?
Weres a good place to pick up a short shifter for 98 1.8. I heard ebay but for 20 bucks that seems too cheap. Looking to spend max 120 unless ebay ones are good then I will go with that use the rest of the money towards something else.
Old 10-14-2010, 08:12 PM
aledelic42's Avatar
http://cgi.ebay.com/ebaymotors/96-97...Q5fAccessories I've used these ebay ones on both my b5's. it's a replica of more expensive b&m shifters and you can use the b&m instructions
Old 10-15-2010, 06:46 PM
lolo22's Avatar
Thanks looks like I will be ordering it this weekend.
Old 10-15-2010, 09:13 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Any downsides to it Alex? (It is Alex right?)
I was going to hold off on getting a short shifter until I could go for broke and get the JHM one, isn't the ebay one made of plastic?
Old 10-16-2010, 08:26 AM
chocalotstarfish's Avatar
Super Moderator
Old 10-16-2010, 09:34 AM
aledelic42's Avatar
No downsides really.. I had to use a dremel and expend the slit that is used for push down reverse (or you can use non push down). The bushings that it comes with are pretty hard to install so I just didn't. After I got it installed I haven't had any problems. It was good enough for me to buy it again
Old 10-16-2010, 09:52 AM
CCA4's Avatar
I've used them on both my B5's as well. No problems. LM, the eBay shifter is all metal, my OEM shifter was actually plastic though. This is one of those things that isn't too good to be true lol
Old 10-16-2010, 03:30 PM
lolo22's Avatar
The more I look at the jhm solid short shifter the more I wanna go and drop 280 for it. Those videos draw you in. lol. Im guessing thats the best of the best right.
Old 10-17-2010, 12:21 AM
Mike-2ptzero's Avatar
Yes the JHM is the best shifter because it uses a sealed bearing. Might also want to do the 2 JHM shifter linkage upgrades. Makes the shifts even more crisp.
Old 10-17-2010, 04:18 AM
eBay short shifter ordered...I'm hoping for the best; but I'll have my critical glasses on.
Quick Reply: Short shifter?
