sensitive ABS
sensitive ABS
I had the car with the mechanic recently having some work done. among the things done was a new CV Boot on the drivers side. from it was installed when ever i press the brake pedal as i am slowing i can feel the ABS kick in. it only really happens as i am rolling to a stop. the mechanic had it back and hooked it to the computer and said there were no errors and it will settle down. i believe there is an ABS ring on the CV boot. could it be because this is new that it is triggering the ABS.
Any Thoughts?
Cheers.
Any Thoughts?
Cheers.
your mechanic messed up the abs sensor on the hub of the changed boot. it could just be a loose harness. it could also be a dirty abs sensor that just happened to start messing with you after the boot change. i have the same problem but mine started after i changed my caliper. it's too cold to properly fix my problem so i just pulled the abs system fuse lol.
