seafoamed 3 days ago... now doin an oil change today
RE: seafoamed 3 days ago... now doin an oil change today
dude wtf... the 18mm nut freakin stripped the bolt....
and how come the oil nut that i got off ecs tunning is bigger then the one im trying to unscrew?
read my comment above. mine is 17mm and on the drivers side
on this link tho it shows it as being 19mm on the passenger side- http://www.fastaudi.net/a4/library/oilchange.html
and also when i went to the dealer and told them i needed a new crush ring for the drain plug they gave me the wrong size even tho i told them it was a 98 AEB. they said there are 2 different sizes.
guess there is just a couple different options for AEB.
ok... so i went back... got a 11/16" socket... because the only 17mm they had was for a 3/8" wrench.... so... i try it and still no luck... wtf did they use to tighten that bolt... Holy Shat!
wtf do i do now? this is ridiculus already!
#18
I didn't see anyone correct you, but if I'm wrong, fahgiveness, pwease.
You'll need to buy 5 quarts of oil. With the big filter, it comes out to like 4.3-4.5q to fill her up.
