Seafoam just in gas tank- same results?
I called up one of my mechanics today about a tune up. I mentioned seafoaming. He knows what it is, and told me to just put it in the gas tank. I asked him about the 33% gas tank 33% oil 33% vacuum and he said it will do the same if I just dump it in the gas tank.
Is this true? will it cleanse everything that the 3-part system would cleanse?
Also, my car has over 222K on it... I am nervous that if I seafoam it it will actually plug the sh*t out of my valves and cylinders due to the speculated (high) amount of carbon build up involved.
Lastly, I am doing a tune up. Everything is fine with the car but I just want to do a tune up. Will just the plugs/wires and fuel filter suffice? (maybe seafoam, if no one talks me out of it from the above question)
i just sefoamed my car about a week ago and i did most of it through the vacuum and a lil bit in the oil if i were you id do the 33% thing or another way is a whole bottle in gas than half and half between oil and vacuum it says on the bottle what it does when its ran through each thing and also says how much to use.
Yeah take off ur 710 cap and pour some in there.
what???? oil goes in the oil cap, so if you want to mix something with the oil, you put it in the oil cap.
