Seafoam on a 2.8
Old 06-22-2008 | 04:47 AM
q0192837465's Avatar
Default Seafoam on a 2.8
I wanted to seafoam my car but the DIY is for a 1.8. Does anyone have picture instructions for a 2.8?
TIA
Old 06-22-2008 | 10:36 AM
ImTheDevil's Avatar
Default RE: Seafoam on a 2.8
If you have a 30v, there is a bracket on the top of the engine, near the rear, with several solenoids on it. Look down and behind it, and you'll see two vacuum lines coming into a Y-shaped piece (that's the suction pump). Each line's outside diameter is a little less than 3/4" (so you know which ones you're looking at). You can undo either of those lines and use it for Seafoam. Each of them has an Audi one-time-use clamp on it, which you will have to destroy to remove, so make sure you have a replacement screw clamp on hand before starting.
If you have a 12v, it's a little farther toward the passenger side, but still in the same main location. It would help if you went to your profile page and made a signature including the specs for your car (see mine below as an example) - that way we can answer your questions more readily in the future.
Old 06-22-2008 | 12:14 PM
96A4Owner's Avatar
Firstly, what year is your car? Give us some info.
If it's a 96 (12v) then here's the DIY on it.
https://www.audiforums.com/m_867698/tm.htm
Old 06-22-2008 | 12:24 PM
rsrbljan's Avatar
if you have a 96, which has the 12v 2.8 in it, the DIY a4owner posted is the same one I used. Worked great.
Old 06-23-2008 | 10:41 PM
Sorry I didnt sepcify. It is a 99.4. I havent taken out the engine cover so I dunno if the inside is similar. I will double check tho. Thanks.
Old 06-24-2008 | 08:59 AM
wildgene789's Avatar
99.4? dont u mean 99.5? lol
Old 06-29-2008 | 11:11 PM
ORIGINAL: wildgene789
Actually, I DO mean 99.4. It's a 1999 January delivery but it doesnt have foglamps, so not a 99.5
This is a pic I took after removing the cover. I am having trouble locating teh vaccuum line to suck seafoam thru. Can anyone point it out for me? Thanks
Old 06-30-2008 | 12:00 AM
hiwords's Avatar
i circled it for ya. have the seafoam flow towards the engine
Old 06-30-2008 | 12:19 AM
^Thanks man. Love ya.
Old 06-30-2008 | 12:31 AM
hiwords's Avatar
sry but i do not condone in homosexual behavior. if you say that again i will have to spank you
