Running Lean
the car would not run rich/lean without throwing a code. if you have a bad o2 sensor on there, u should def. have a code for that and it would change how your engine runs because its not getting info from the sensor.
i have a code for the o2 sensor but nothing else.
you see, when someone asks "do you have any codes?" - 'no' would be the wrong answer if you do have a code.
now -what is the code exactly? P0xxx
what is the A/F ratio then?
and you have yet to provide any details about which car you are talking about. year, engine (assuming a 1.8t), transmission, quattro/fwd. the standard stuff when asking mechanical questions.
i have a diagnostic tool that shows me my engines parameters and it shows that.
