Rpm almost stall issue
is that all? just let it sit. on the other form it said something like push the gas pedal for 5 seconds while in on mode but not started relese or something and it didnt work-_-
then nome one else said disconnect the battery for 15 minutes .. reconect and ul here noises..
Typed in "throttle body adaptation" in the Search box. This is the result. Second post listed tells you how to do the TBA without vagcom (as JBJ said just above your last post).
AudiForums.com - Search Results
Turn on your key to ignition and do nothing for 3 minutes....actually get out and put your ear in the hood...you will hear a tsouuuuuuuuu tsiiiiiiiiiiiii grouuuuuuuuuuuuuuuuuu ntiiiiiiiiiiiii ntiouuuuuuuuuuuuuuuuuuuuu xsouuuuuuuuuuuuuuuuu
Actually thats the noise of a modem connecting...but whatever..you will hear something after 3 mins....worst case scenario to be run over by your car!
