Rpm almost stall issue
Old 09-14-2012, 12:09 AM
kenman's Avatar
Default Rpm almost stall issue
my audi a4 b5 AEB brick 99 . when i turn the ac on and push the gas its fine just ac squeeks idk why but when i relese the gas my car drops into the dangerous 300 rpm range and almost stalls out. then bouncecs to 500. when ac is off this dosnt happen how can i fix this??? any help please also my car is the 5 speed 1.8t
Old 09-14-2012, 07:03 AM
Gasketse's Avatar
I have the same issue as well!!! My car stalls when my AC is on sometimes! Solutions?
Old 09-14-2012, 07:05 AM
jonbonesjones's Avatar
Moderator
mine raises when i turn the a/c on. How tight is the belt? Also check for vaccum leaks.
Old 09-14-2012, 08:56 AM
ImTheDevil's Avatar
It's worth doing a throttle adaptation as well (search feature will reveal how). Over time your throttle can lose alignment and you may be a little low, enough that the increased load on the engine from the AC causes it to bog.
Old 09-14-2012, 09:09 AM
Gasketse's Avatar
will do a throttle adaptation....and get back to you.....
Old 09-14-2012, 10:58 AM
MetalMan's Avatar
Moderator
Also could be vacuum leaks. It's worth doing a test for them, especially if your car still has 11+ year-old rubber hoses.
Old 09-15-2012, 01:12 AM
kenman's Avatar
how do i do a throtle adaption?? whaaa...and my previous owner installed some aluminum thing i think its a bancy blow off valve comes from the intake vacume line that originaly had 2 hoses now has a screw and one hose going to the blow off valve ... i highley doubt it is anything to do with vacumes...but how can i do a throttle adaption
Old 09-15-2012, 01:23 AM
kenman's Avatar
well nevermind google answered it haha thank you for the answers tho guys big help=)
Old 09-15-2012, 02:25 PM
kenman's Avatar
ok so on google all i found was that u have to have vag com but some people said some little trick i purchased a kkl hong cong stupid vag com cable that im sure wont work when it gets here 7$ down the toilet so can someone tell be the secret trick to make it do its own throttle body adjustment
Old 09-15-2012, 04:04 PM
Moderator
turn the key without starting the car and let it sit. you'll hear some noise under the hood.
Quick Reply: Rpm almost stall issue
