Rpm almost stall issue
my audi a4 b5 AEB brick 99 . when i turn the ac on and push the gas its fine just ac squeeks idk why but when i relese the gas my car drops into the dangerous 300 rpm range and almost stalls out. then bouncecs to 500. when ac is off this dosnt happen how can i fix this??? any help please also my car is the 5 speed 1.8t
It's worth doing a throttle adaptation as well (search feature will reveal how). Over time your throttle can lose alignment and you may be a little low, enough that the increased load on the engine from the AC causes it to bog.
how do i do a throtle adaption?? whaaa...and my previous owner installed some aluminum thing i think its a bancy blow off valve comes from the intake vacume line that originaly had 2 hoses now has a screw and one hose going to the blow off valve ... i highley doubt it is anything to do with vacumes...but how can i do a throttle adaption
ok so on google all i found was that u have to have vag com but some people said some little trick i purchased a kkl hong cong stupid vag com cable that im sure wont work when it gets here 7$ down the toilet so can someone tell be the secret trick to make it do its own throttle body adjustment
