Rough Running
Old 07-31-2008 | 10:07 AM
mjscc1's Avatar
Default Rough Running
2.8 runs very rough when cold. RPM's surge but after about 1-2 minutes smooths out and runs fine. Any ideas.
Thank you
Old 07-31-2008 | 10:42 AM
cartercdad's Avatar
Default RE: Rough Running
maybe fuel filter or pressure regulator
Old 07-31-2008 | 11:02 AM
jiggleo's Avatar
sounds to me like an egr. try not to post the same issue twice in the future.
Old 07-31-2008 | 11:57 AM
mjscc1's Avatar
Default Engine idles rough at cold start
Starting engine cold RPM's surge up and down. Low RPM's runs rough then spike to about 1500 and smooths right out. Drops back down then surges again. After about 60-90 seconds it runs fine and all gages read normal. HELP!!!
Old 07-31-2008 | 11:59 AM
mablo88's Avatar
Default RE: Engine idles rough at cold start
I have the same problem on my 2.6. As I understand this is a quite normal issue with the 12v's(if that is what you have?), but i don't know what is causing it.
Old 07-31-2008 | 12:46 PM
hiwords's Avatar
seafoam treatment
Old 07-31-2008 | 02:10 PM
mjscc1's Avatar
I've used Techron by Chevron in the past. Is that comparible to Seafoam? Thanks
Old 07-31-2008 | 06:34 PM
Tweaked's Avatar
ORIGINAL: mjscc1
Any MIL or codes?
Try unplugging the secondary air pump and starting the car cold.
someroad
08-06-2013 12:53 PM
quattroforthewin
03-28-2011 04:46 PM
yesss4
08-23-2009 12:14 AM
bubbasmurf84
07-19-2009 11:01 AM
Dave Crall
02-22-2008 03:16 AM
