Rough Idle Problem
Old 10-23-2010 | 12:26 PM
HeyCesar's Avatar
Default Rough Idle Problem
Went I start the car the rpms will go up and down from normal to wanting to die repeatedly for about 4 seconds then it'll idle normally. Same thing if I rev it, when I let go it'll go rough for a few seconds then return to normal.
Any ideas on what this could be?
Have new sparkplugs and ICM.
Old 10-23-2010 | 01:52 PM
a4nick's Avatar
MAF! lol is it every time you start or just at cold? mine did this for 2 minutes on cold starts and then would run fine i cleaned the maf and it doesn't do it anymore start from there
Old 10-24-2010 | 02:26 PM
HeyCesar's Avatar
It does it even after it warms up.
Old 10-24-2010 | 02:36 PM
Fresh.Clean.Classy's Avatar
When did the problem start? Did these problems start after you replaced the sparkplugs and ICM?
Old 10-24-2010 | 05:59 PM
HeyCesar's Avatar
I just recently bought the car and it came with that problem along with a bad ICM (2nd cylinder was not firing at all) so I replaced the ICM and spark plugs too while I was at it.
justinclarke
11-25-2010 05:03 PM
frizle2001
07-25-2009 02:41 AM
MikeInMexico
10-24-2008 04:25 PM
templefitness
09-16-2008 09:03 AM
