Rough Idle
Old 08-25-2008, 06:24 PM
chito31's Avatar
it may be too soon still.... but CEL was flashing again, so I guess the misfire is still there.... any suggestions?
Old 08-25-2008, 06:26 PM
Jc61990's Avatar
vag-com to clear codes, as for the misfire, maybe you shuold pull out your plugs and check them, make sure the gap is correct. anywhere between .028 - .035 should be good. and did u try seafoaming your car?
Old 08-25-2008, 09:46 PM
chito31's Avatar
spark plugs are only a couple of months old but I'll check that out too... My mechanic didn't seafoam it but he used a similar product (forgot the name, sorry). Pumped it through intake and also into gas tank. Car felt great right after but I got a misfire later in the day. Will give it a couple of more days though so it can work itself through the fuel lines and injectors.
What should the idle RPM be.... mine is around 700? is that too low?
Old 08-25-2008, 10:00 PM
Jc61990's Avatar
that sounds about normal
edit: went and took a picture of my car in idle
Old 09-02-2008, 01:59 PM
chito31's Avatar
hopefully my last update...
coilpack and fuel injectors were ok. Turned out to be just the plugs and wires. So relieved! Plugs were all gooey.... maybe that happened when engine was cleaned out.... hopefully I don't get any more CELs.
jsweete
01-29-2016 08:42 AM
rekabj1108
04-19-2012 10:47 AM
justinclarke
11-25-2010 04:03 PM
Swami51
11-04-2008 05:08 PM
Quick Reply: Rough Idle
