Replacing rear wheel hub and bearings???
I hate it when my ABS sensor's drive belt is missing some teeth, almost as much as when I run out of turn signal fluid.
and you allso might need probe to check for the idle fluid level in the oil pan
#19
I'll try and find the DIY I used and was super easy. All I can remember was it was a yellow b5 used in the diy pics!
#20
oh,you forgot the most important thing,you have to check to see if your missing teeth on the horn belt,god forbid that snaps!
