Replacement stereo
Old 07-21-2011, 05:49 PM
meikle's Avatar
Default Replacement stereo
Hi all,
I'm wanting to replace the stock stereo in my 2001 A4 with myTouch screen DVD player, can anyone tell me the colour coding of the wiring & also is it possible to connect my iphone to it so I can control through the touch screen.
Thanks for any help
Col
Old 07-21-2011, 07:26 PM
Audisaurus's Avatar
Radio would have to have iphone support.
Theres either a wiring diagram on the top of your old radio or the internet can helps. Use a wiring adaptor
Amazon.com: Stereo Wire Harness Audi A4 A8 96 97 98 99 (car radio wiring installation parts): Electronics
Easier to do RNS-E upgrade but more expensive.
Old 07-22-2011, 03:59 AM
meikle's Avatar
Hi,
Thanks for reply,
I have the adapter but it's the colour coding from the car I need help with, I know the earth (brown) wire but not sure about where the battery & memory wires go.
I think I'll just get a iphone to RCA CABLE & forget the touch screen lol.
Cheers
Old 07-22-2011, 08:58 AM
Audisaurus's Avatar
well what model touch dvd do you have?
If you have the adaptor it color matches to the aftermarket harness that came with the touch dvd. then just plugs into the car. dont have to tap anything
Old 07-22-2011, 05:34 PM
meikle's Avatar
Can I put it a different way, can anyone please tell me what each wire does (except speakers) coming from the car?
Cheers
Col
Old 07-22-2011, 06:55 PM
Audisaurus's Avatar
thats your radio just match them you only need power ground acc and illum if your speakers are amped
Old 07-26-2011, 02:03 PM
meikle's Avatar
Hi,
This is doing my head in LOL,
I've got the ground & got the battery wires from the car but when I connect the ACC wire from the stereo the unit stays powered on constantly even when the keys are removed.
Can anyone please tell me if there is a solution to fix this.
Many thanks for any help.
Col
Old 08-04-2011, 06:00 AM
meikle's Avatar
OK, finnally got it susssed, the problem was that the origional leads did'nt have a wire to go to the ignition so i just took a wire from the fuse box.
Can anyone tell me what this yellow plug & cable from the car to the stereo is?
Thanks
Colin
Old 07-25-2012, 06:07 AM
bangkok paul's Avatar
Default radio wire
that is a ant plug you do not need it just tape it up it is only used on audi head units. hope this helps you.
Old 07-25-2012, 07:46 AM
jonbonesjones's Avatar
Moderator
try reading the date
Quick Reply: Replacement stereo
