Repair Bill
Repair Bill
Hi everyone, just got back from ordering parts and everything i was wondering if this is a good price, seems like it is but i wanted to make sure that i'm getting a good deal. The mechanic is going to change all these parts (my cost 850) and charge 950 in labour.
PCV Valve
Vacuum Valve Check Valve
Over Run Cut Off Valve
Pentosin Oil
Oil Filler Cap
Oil FIlter
Oil Pan Gasket
Oil Filter stand Gasket
Oil Pump
Tensioner Gasket (camshaft)
Timing Chain Tensinoner (camshaft)
Timing Chain
Camshaft Seals
Intake Manifold Gasket
Exhaust Manifold Gasket
Turbo Exhaust Gasket (Cat Conveter inlet)
Turbo Exhaust Gasket (manifold)
Cylinder Head Gasket Set w/Valve Cover
Water flange
Air Condition Tensioner
Timing Belt
Timing Belt Tensioner Dampener
Basically he said your doing 80% of an engine rebuild just missing intake exhaust valves, and actual cylinders.
He also asked if wanted to change my piston rings wondering if that is worth it, they run about 200 dollars more for all 4?
PCV Valve
Pentosin Oil
Oil Filler Cap
Oil FIlter
Oil Pan Gasket
Oil Pump
Timing Chain
Camshaft Seals
Water flange
Timing Belt
No sludge, engine is actually really clean. Im having gaskets and seals go on me frequently so changed the whole pcv system now. But the head gasket was gone, rear main seal was gone, valve cover was gone. And the timing chain tensioner was ticking pretty bad so decided to get it out of the way. The rings i dont know if they need to be changed mechanic is a "buddy" said if you want to buy them and he will change them for free hes got everything apart anyways doesn't mind do the extra work. He said would be better compression, but i dont know if there is a problem with compression. Thats why i was wondering if its worth it or not, if anyone has any experience
Cobbacorn
02-05-2013 09:57 PM
lilhgarcia1
12-14-2011 06:10 PM
