Removing Cats?
straight from 034's website
"This stainless and mandrel bent 3" racing downpipe replaces the restrictive catalytic converter located behind the turbo on longitudinally mounted 1.8T engines. The downpipe has a large 3" opening to increase turbo efficiency and is surprisingly silent when used with the stock exhaust system in place. Expect spool-up to arrive 200 to 400 rpm earlier, and at least 40ft/lb of torque to the wheels!!
Typical horsepower gains range from 10hp+ with a stock turbo, 15hp+ with a K04, and 30-40 horsepower when combined with a GT28RS or larger turbo. Includes provisions for factory oxygen sensors. --For OFF-ROAD use only! "
Just get a set of non foulers part 42009, they will come up as spark plug non-foulers, but fit perfect. Thats what i used. grinded one down with a dremel (or drill) and stacked the 2 together. No cel yet!
I LOVE my test pipe. The sound is great and it added a noticeable little punch. Smell really isnt THAT bad. and its a hella lot cheaper than the labree. Id say go for it unless you have emissions testing.
Check allofcraigs.com
Thats where i always look first. Got my brand new balieys dv for $25 off, and my test pipe used for $85. Also looking at a gently used carbonio for only $200
Thanks for the info.
