Regulator & motor replacement troubles..
So I picked up a new window regulator and motor assembly. This was the only part listed for all models of the B5 A4 generation. I have gotten the regulator mounted but here is my problem. The previous wiring harness connector has somewhere close to 10 or more prongs for all of the various wires on the driver side front motor. My problem, the new one I received only has two prongs. I've used banana plugs to test each wire from the wire loom to each of the two prongs on the new motor to no avail 40% of the wires when connected to either prong either makes the window go all the way down or up immediately. I'm at a loss as this is the only part listed in WORLDPAC for the B5 A4, thus I'm sure someone else has experienced this. I can't swap the motors from each assembly as they are built in on both the original one and the new one I purchased. Please help, thank you!
