rear wheel bearing
rear wheel bearing
is this the right one i need for the rear drivers side?
http://www.partsgeek.com/mparts/wheel_bearing/audi.html
It is the same whether right or left side. it is also used in the front on some cars i believe.
If you are Fwd, then you need the bottom one on that list i believe.
good luck
YEP. I ordered mine from blauparts i believe when i did mine. im pretty sure if you look there it will tell you the same info.
well.. i would maybe just get them from blau.
they are reputable. Cheap too. And they come with the new axle bolt and some of the other bolts/nuts you have to remove to do the job
http://www.blauparts.com/proddetail.asp?prod=F7W1006-A
Kyle_vdk
01-11-2014 10:25 PM
Anybodykilla
05-03-2006 10:46 PM
