rear caliper carrier/sliding pins
Old 08-13-2008 | 07:19 PM
paintballpimp765's Avatar
Member
Default rear caliper carrier/sliding pins
ok so im in the middle of changing out my rear rotors and pads and one of the slider pins that goes into the carrier was stuck in the carrier and it broke when i tried to get it out. i was able to get the broken sliding pin out but the problem is i cannot find anyone who sells the sliding pins by themselves and i dont want to pay 70$ from ecstuning for the whole carrier when mine is fine, and then have to wait for it to arrive before i can drive. anyone know of anywhere to get the pin or any other suggestion? thanks
also another quick less important question, i was told my coolant reservoir is cracked but i cannot see any cracks in it, is the reservoir the plastic piece that the coolant is poured directly into or is there like a hidden reservoir that im not seeing?
Old 08-13-2008 | 07:58 PM
auditech79's Avatar
The dealer is the only other place you can get a new pin, they run like $40.
I wouldn't buy a used one.
Old 08-13-2008 | 10:58 PM
jokeabus's Avatar
The reservoir probably has a few stress fractures from the heat of the engine. If you can't see anything, its unlikely you have to change immediately. I've been told the same thing about mine, and from what I can see its still in great condition. It's just one of those things you need to keep an eye on.
Old 08-14-2008 | 12:02 AM
Member
thanks for the quick replies guys, yea mine leaks a little bit, just something i was looking into before going back to college for the year because its 3 hours away and theres no where to get parts besides auto zone, so im trying to take care of the little things
Old 08-14-2008 | 12:23 AM
hiwords's Avatar
Old 08-14-2008 | 06:18 PM
Member
ok so this is starting to frustrate me. thanks for the info on the pins i ended up getting them today and gave them to my buddy whos shop is changing my rear rotors (i got fed up with it) and now he is telling me i have the wrong pads. i ordered the full brake kit off of mjm (http://www.mjmautohaus.com/catalog/p...oducts_id=2149)
and now he is saying that the pads wont fit in the rotors, the top of the pads sticks out to much and wont fit inthe rotor. i also picked up a pair of pads from carquest and they do the same thing. ive double checked both places and both say they are the right pads. am i just having bad luck or does my buddy not know what he is doing?
aloo
11-06-2011 12:23 PM
jasonelement2010
08-02-2011 02:36 PM
jasonelement2010
07-10-2011 08:54 AM
Necoo
09-26-2010 08:22 PM
wood_e
09-20-2006 02:58 PM
Quick Reply: rear caliper carrier/sliding pins
