Really slow to accelerate, but no CEL
Old 03-11-2011, 11:29 PM
RyanSweeney's Avatar
Default Really slow to accelerate, but no CEL
Hey guys...my car is all the sudden accelerating really slowly. It doesn't give a CEL, so what on earth could it be? I made a 300 mile round trip one day and it seemed fine. The very next day when I got in it to run an errand, it seemed like I was pulling a boat with it.
I've not had good luck with mass airflow sensors in the past. The original one went out, and I replaced it with a remanufactured one from O'Reilly auto parts. That one lasted all of 6 months and then it went bad. I'm running on the second one from O'Reilly. Now the car is running sluggish again, but it isn't stuttering like it did when the other two went out.
Could it be the MAF again?
Old 03-11-2011, 11:55 PM
kduznetsov's Avatar
Run codes?
Old 03-12-2011, 12:12 AM
pbrules10's Avatar
Bad plugs? Vaccuum leak?
Old 03-12-2011, 12:18 AM
NHolzschuh's Avatar
u may wanna post what engine/trans u have, year is helpful to.
Old 03-12-2011, 07:34 AM
ImTheDevil's Avatar
Check for a stuck caliper too, especially a rear one. Seems like the e-brake likes to bind or seize sometimes on these cars.
Old 03-12-2011, 09:39 AM
Run codes????
I have a 1999 A4 with the AEB engine and Tip tranny, 1.8T
Old 03-12-2011, 09:52 AM
I just changed the plugs not long ago. The thing is, the car idles just fine....perfectly smooth and normal.
Old 03-12-2011, 10:00 AM
ImTheDevil's Avatar
Vacuum leak is possible. Run codes = get ECU scanned for fault codes.
Old 03-12-2011, 10:20 AM
Can they do that at Autozone? Or is that something that has to be done specifically with a VAG?
Old 03-12-2011, 12:32 PM
morpheous's Avatar
Autozone's scanner will only look for engine DTC's,nothing else. vag-com cables,along with vag-com software are way more thorough and will scan the entire car,plus allows you to program your B5 to do things that are hidden,within the factory settings that lay dorment.
Quick Reply: Really slow to accelerate, but no CEL
