This is REALLY bugging me out!
I've finally installeda MBC to get rid of the boost-fluctuations and everything works great. Except for one thing.
My chip boosts 1.35 bar. My mbc is put to 1.3-1.4 bar. BUT, after driving on full throttleon 4th and 5th gear a little while, the car chops, probably fuel-cut. No overboost, just stable boost around 1.3-1.4 bar.
This seem to happen ONLY when it's getting a little cooler outside.
So what's the deal? It can't be the boost, because as I said, the chip is set to 1.35 bar and the car peaked @ 1.45 earlier today without any problems.
I also changed my spark plugs to platinum plugs.
Please help! :'(
Please help! :'(
RE: This is REALLY bugging me out!
<\\;P>\\;A mechanical, the one i showed you.<\\;BR>\\;I have the bleed-side plugged into the recirculation, where the n75 was. After the MBC is a tee to reach my desired boost (1.3bar) otherwise i will only get maximum 1.1bar<\\;BR>\\;The plugs are brand new platinum ones, NGK PRF 6Q, i don&rsquo;t know the gap.<\\;BR>\\;<\\;/P>\\;
I noticed that when I'm on fifth gear and a little load (still chilly outside) the boost raises to 1.45bar insted of the set value of 1.35bar.
is it because of the placement of the tee?
http://www.nordicaudi.com/php/files/882136-DSC02066swe.jpg
If i move the tee to before the MBC, will i get rid of the unwanted increase? will my spool-up be affected?
C'mon, someone had to have this problem before
plumbous
12-30-2005 07:21 AM
