Re-using/refilling coolant question
Hey guys,
So tomorrow I'm going to change my thermostat and I had a few last questions.
1st question: Can I re-use the same the coolant that I drained out? The problem is I only have about 1 liter of G12 and the dealer wont be open tomorrow to get any more...
2nd question: When I'm refilling the coolant do I do it through the overflow tank or is there a place on the top of the rad where I fill it directly? Do I put it all in one shot or do I put like half, run the car to let it circulate, then put the rest? What exactly is the procedure for this?
Thanks
Thanks
1. make sure you drain it so nothing gets in it and use a clean container.
2. yes fill it through the overflow tank but undo the 3 screws cuz you'll need to get some of the air out of the system by raising the reservoir. for example, poor coolant in and it'll look full, raise the tank, lower it again and poof it'll be low on coolant again lol. put everything in and then let the car run.
