radio problem
radio problem
i have a 01 audi a4 with a symphony radio the radio quit working pulled the fuse checked good put fuse back in radio works again until i cut the iginition off then it quits i have checked both power sources (continuous & switch) both have power when radio is not working tried two other radios with same results. anyones help would be appreciated.
A higher rated fuse is not the answer! Fuses are rated differently, and blow for a reason. I'd have to guess it's a bad ground, and as much as I hate to draft auditech into it since he's bombarded on a full time basis, he'll probably have a good answer.
he said the fuse didnt blow
