Radiator flush and t-belt?????
I am flushing radiator tomorrow and I am curious if the red stuff audi gives u is a 50/50 mixture or if I have to mix it myself.
Also I wanna check my t-belt but I don't wanna take the whole front end off the car. Is there anyway to do that?(I have a v6 30v)
G12 is antifreeze....which means that it needs to be mixed 1:1 with water...
I don't know about the best way to check the t-belt on a 2.8...should be pretty easy to locate...on the 1.8 you can either pop off a plastic cover at the front of the motor or take a look from the underside....
besides that, when was the last time your t-belt was changed?....the general rule of thumb is every 80-90k....if you don't know when the last time it was changed if ever...I would suggest changing it....a t-belt can look just fine and still break....
well, hope something in there helps....gl!
I honestly have no idea when anything was done. I bought the car and they had no records on it. I wanna change the t-belt but I really don't know how and I don't have the time. I am super nervous everyday though that that thing will go. The car has 113000 on it. Which hose do I disconnect to drain the radiator coolant? And is there a diy for the t-belt on a 30v?????
your radiator should have a drain plug so you don't have to disconnect the hose. at least it does on the 1.8
http://www.audiworld.com/tech/eng42.shtml
