just installed my vdo boost gauge today. the normal boost level is around 7psi right? i just went out for a ride and looks like it spiking betweem 10-11 psi.
when the crappy sidemount gets heatsoaked its possible. stock boost on AEB is 8psi, stock boost on 99+ is an extra 2-3 psi. unless the gauge is digital its only accurate +/- 2psi remember.
Stock boost on a 2001 is .8 bar which is 11.6psi, so you should see it hit 11-12psi and then taper off. This is why the 2001 came with 170hp stock vs the pre 2001 cars which were 150hp stock.
so in order to hold better boost.... trash the sidemount and go with a front mount?!?
only thing i hate is the sensor for the intercooler!! i have pipes and a core to play with but the sensor in the way!
