question before chipping
Old 01-19-2009, 09:10 PM
less_of_me's Avatar
Originally Posted by mrbloink
Is there a good DV that people could recommend?
You can get the 710n from your local dealer. It is off a TT and it will be able to handle the boost you are going to make. If you feel like spending more money (which you don't need to) you can do a search on these forums for "diverter valve" and I'm sure any other options will appear.
Old 01-19-2009, 09:45 PM
A4speed's Avatar
yeah, theres the forge 007 and APR R1 dv's that both work well if u dont want the 710n.
Old 01-20-2009, 12:27 AM
ghost6303's Avatar
if you have the 710n valve, install it in the direction that your stock one comes off. if you have a nice aluminum or steel DV, install it in whatever direction holds the most pressure, usualy that is pressure hose to the side of the DV, not the bottom of the DV. but they are all different. really it doesnt matter much for your setup.
Old 01-20-2009, 10:00 AM
mrbloink's Avatar
Ok thanks for all of your help.
So i should just order 4 spark plugs and a new DV. well besides sending out my ecu. I shouldn't need new injectors correct?
Oh and what heat rating should the spark plugs be. I was thinking about 6?
Old 01-20-2009, 03:14 PM
onepoint8tee's Avatar
NGK BKR7E or 6E @ .028
Get a used aluminum dv like a Forge for a little more money if you can. It lasts forever and there are no rubber guts to tear.
Old 01-21-2009, 12:36 PM
mrbloink's Avatar
I guess i will take a trip to the classifieds.
If I will be replacing my vacuum lines, should i get this done professionally, or if its not to hard, is there a write up?
Old 01-21-2009, 12:53 PM
AutoUnionFan's Avatar
do the vaccuum lines yourself, just pull out the old braided lines and replace with new lines - not that hard
  #18
Old 01-21-2009, 01:11 PM
mrbloink's Avatar
EDIT:
Never-mind, stupid question.
Thanks everybody for all of your help.
A_Plus_Remodeling
11-04-2009 03:36 AM
thetryal
10-17-2007 07:08 PM
joelml
06-12-2006 07:01 PM
MeanAudiA6
03-08-2006 04:51 AM
cgv988
04-20-2005 11:58 PM
Quick Reply: question before chipping
