Question about my codes
Old 02-10-2011, 11:01 PM
Nevalite's Avatar
Default Question about my codes
Here they are:
Code:
VCDS-Lite Version: Release 1.1
Thursday, 10 February 2011, 22:56:28.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77
Address 01: Engine       Labels: Redir Fail!
   Controller: 4B0 906 018 P
   Component: 1.8L R4/5VT     G   0006
   Coding: 07201
   Shop #: WSC 06335
   VCID: 2E2F8DBBF919
1 Fault Found:
17522 -  Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
            P1114 - 35-10 -   - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes       Labels: 8E0-614-111-ABS.LBL
   Controller: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Coding: 0273004284
   Shop #: BB 24334
   VCID: 1C4B57739FA5
No fault code found.
So I guess the first one is the O2 sensor, I cleared it to see if it comes back. I dont have a check engine light.
My problem is with the second one, it says ABS, but then it says no fault code found, the problem is that on my LCD I see the circle with the two tangent arcs beside it (ABS warning)...so how can I clear it off my screen if theres no fault code being given?
Thanks
Old 02-10-2011, 11:04 PM
auditech79's Avatar
Unplug your ABS control module then plug it back in again (with the key off) See if the vag com will communicate with it again.
Old 02-10-2011, 11:12 PM
Nevalite's Avatar
It's on the driver side, near the coolant tank kinda with all the brake lines going into it right? I'll give that a shot.
Old 02-10-2011, 11:14 PM
auditech79's Avatar
Yes, thats the ABS block and module.
Old 02-11-2011, 12:40 AM
Nevalite's Avatar
Ok so I unplugged and repluged the ABS module, didnt make a difference. The ABS light on the dash itself is not on, just the one in the LCD display. How can I clear it?
Old 02-11-2011, 01:06 AM
Nevalite's Avatar
After checking through the Ross-tech site I think this will get rid of it:
Code:
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
If I removed the brakepad wear sensor I think that would fix it. It must be break pad wear light and not and ABS light.
Anyone ever had this?
Old 02-11-2011, 12:04 PM
morpheous's Avatar
ummm...there is nothing wrong,that icon on your dash,warns you that your brake pads are worn and need replacement,a simple look through your cars A4 manual would have told you what that icon means,when it appears on your dash.
When that icon came up on mine the very fist time,since i owned my B5,i looked in the manual and knew what it meant,i changed the back first,it didn't go away,then i figured the brake pad sensors were in the front brake pads,changed the front pads and it finally went away.
That o2 sensor is obviously another matter altogether but i think you know what to do with that...replacement time
Old 02-11-2011, 12:11 PM
Nevalite's Avatar
Yeah I have had that light for some time but I just changed all my pads and all my rotors and the new sensors in the front are connected. Also I checked the level of my brake fluid and it is fine.
So I have the light for no reason and can't figure out how to get it to go away...
Old 02-11-2011, 01:43 PM
morpheous's Avatar
Did you clear all your codes with your vag-com to see if that clears the icon?
Old 02-11-2011, 03:14 PM
Nevalite's Avatar
This is what I have now:
Code:
   Coding: 07201
   Shop #: WSC 06335
   VCID: 2E2F8DBBF919
   Coding: 0273004284
   Shop #: BB 24334
   VCID: 1C4B57739FA5
New pads, new rotors, plenty of brake fluid, but I still have that (O) in my LCD...
Any ideas?
Quick Reply: Question about my codes
