Question about my codes
Here they are:
So I guess the first one is the O2 sensor, I cleared it to see if it comes back. I dont have a check engine light.
My problem is with the second one, it says ABS, but then it says no fault code found, the problem is that on my LCD I see the circle with the two tangent arcs beside it (ABS warning)...so how can I clear it off my screen if theres no fault code being given?
Thanks
Code:
VCDS-Lite Version: Release 1.1 Thursday, 10 February 2011, 22:56:28. Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 4B0 906 018 P Component: 1.8L R4/5VT G 0006 Coding: 07201 Shop #: WSC 06335 VCID: 2E2F8DBBF919 1 Fault Found: 17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High P1114 - 35-10 - - - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL Controller: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Coding: 0273004284 Shop #: BB 24334 VCID: 1C4B57739FA5 No fault code found.
Thanks
After checking through the Ross-tech site I think this will get rid of it:
If I removed the brakepad wear sensor I think that would fix it. It must be break pad wear light and not and ABS light.
Anyone ever had this?
Code:
[Select] [17 - Instruments] [Recode - 07] Write down the existing coding for future reference. Enter 5-digit code from below [Do It!] Look at the first two digits in the coding. Add the values for the options together to get the correct coding. 00 - No available equipment +01 - Brakepad wear sensor warning active +02 - Seatbelt warning active +04 - Washer fluid level warning active (may only work with pre-2000 models) +16 - Navigation System (non-USA models)
ummm...there is nothing wrong,that icon on your dash,warns you that your brake pads are worn and need replacement,a simple look through your cars A4 manual would have told you what that icon means,when it appears on your dash.
When that icon came up on mine the very fist time,since i owned my B5,i looked in the manual and knew what it meant,i changed the back first,it didn't go away,then i figured the brake pad sensors were in the front brake pads,changed the front pads and it finally went away.
That o2 sensor is obviously another matter altogether but i think you know what to do with that...replacement time
Yeah I have had that light for some time but I just changed all my pads and all my rotors and the new sensors in the front are connected. Also I checked the level of my brake fluid and it is fine.
So I have the light for no reason and can't figure out how to get it to go away...
This is what I have now:
New pads, new rotors, plenty of brake fluid, but I still have that (O) in my LCD...
Any ideas?
Code:
VCDS-Lite Version: Release 1.1 Thursday, 10 February 2011, 22:56:28. Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 4B0 906 018 P Component: 1.8L R4/5VT G 0006 Coding: 07201 Shop #: WSC 06335 VCID: 2E2F8DBBF919 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL Controller: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D10 Coding: 0273004284 Shop #: BB 24334 VCID: 1C4B57739FA5 No fault code found.
Any ideas?
