Punctured oil pan
Punctured oil pan
Hey guys, i've got a 98 2.8 quattro and when i went to leave today i noticed oil all over the floor of my garage, when i checked under the car i saw two chunks in my oil pan dripping out oil. I was wondering if anyone knew where i could order a replacement pan and how much of a headache i'm getting myself into replacing it myself.
install is dumb easy. you take out the 10mm(or 8mm?) bolts around the pan, undo the harness on the oil pressure sensor and then try to get something between the oil pan to get it off. that last step may take the longest. make sure you have gasket sealer like red ATV for the install. clean the surfaces where the oil pan meets the engine and vice versa, put everything back on, and fill the car with oil. boom you're done. shouldn't take more than 4 hrs for the first time even for somebody knew at DIY.
Hmm, really? Cause for the 1.8 I've read you have to drop the subframe in order to get the pan out. I'm about to do mine due to it being cross threaded but i've been dreading it due to dropping the subframe.
Please tell me I'm wrong.
BUT ALL WAY'S REMEMBER CLEAN OUT THE OLD GUNK FROM THE OLD PAN THAT WAS TOUCHING THE BLOCK BECAUSE IF YOU DON'T YOUR GONNA HAVE TO GO BACK THERE AND DO IT ALL OVER AGAIN AND THAT SUCK'S.
Well i got my broken oil pan off quite easily, threw some JB weld on the cracks and hopefully that will hold me off until my replacement gets here in a week or so. I have to say, at first i regretted getting the 2.8 over the 1.8T but everything I've encountered so far working on the car, even though I've got a miserable few options for aftermarket parts, given the chance I'd buy the 2.8 all over again.
