Proper Grounding (After Market Stereo Install)
Old 02-26-2010, 12:49 PM
Chewster's Avatar
Exclamation Proper Grounding (After Market Stereo Install)
OK I know other people have put after market decks and equipment in there B5's and this should be a fairly easy question, but I have no clue where to ground in the trunk with out getting alternator whine (that HORRIBLE noise in the speakers from the alternator every time you accelerate it gets louder!!) My RCA's are shielded (all 3 sets) and I know its the ground but everything in the trunk is galvanized SO PLEASE if you have after market stereo equipment in your car PLEASE tell me where you grounded!! and if you grounded the entire system to the same spot???
Old 02-26-2010, 01:04 PM
Andrew149's Avatar
run the ground to the battery
Old 02-26-2010, 01:15 PM
Chewster's Avatar
That's 18ft of ground wire running through a car, Amp's are supposed to have no more than 5ft... Is this what you did??
Old 02-26-2010, 01:29 PM
Chewster's Avatar
long wires = high resistance so keep them as short and neat as possible.
Old 02-26-2010, 01:46 PM
dragonrage's Avatar
I usually ground amps to the lower seatbelt bolts, though I have yet to touch that stuff in my A4.
Old 02-26-2010, 02:01 PM
Chewster's Avatar
Yeah I did that before in other cars as well, I grounded to the latch handle bolt that holds the truck cover in and I get crazy noise through my speakers
Old 02-26-2010, 02:04 PM
Wvjon's Avatar
Member
My amp is grounded to a bolt on the passenger side of my trunk. Under the mat, just above the well where the spare tires is. There is a place where the paint was sanded off and the ground strap is bolted on there.
Old 02-26-2010, 02:07 PM
Chewster's Avatar
Wvjon was this one of the latch bolts that hold the spare tire cover on?? If not what was the bolt for??
Andrew149's Avatar
my amp is grounded to my driver side seat scrape off all the paint and than ground it
Old 02-26-2010, 02:11 PM
Chewster's Avatar
Where is your amp located then??
Quick Reply: Proper Grounding (After Market Stereo Install)
