Problems.. transmission/o2/coolant/many more
I have a ton of issues with my car, and I'm about ready to drop it off at a shop for a week and have them fix the problems. Here is a list of the problems, can any of you guys give me a quote on how much a shop would charge? Also, do you have any other ideas to fix the transmission issues and coolant crap? I guess I didn't flush the heater core well enough during my rebuild after the head gasket failed, because some of the residual gunk is circulating in my coolant system.
Problems:
Transmission pops out of 4th under load
Intermittently wont go into gear/grinds
Replace fluid, adjust linkage, test.
Coolant/oil gunk in coolant system
Serious system flush
Power steering leak
Run new lines from the rack to the cooler.
Front left cv leak
JHM/Raxles front DS axle
front tires rub
Roll front fenders
Bad upper control arm
Replace UCA
CEL from pcv leak
replace broken section of pipe
O2/cat readiness error
Replace rear o2 sensor, test, replace front o2 sensor
(I replaced the cat with a Techtonics tuning hfc because I was getting this error, both of my o2 sensors test as working when I checked them with a multimeter)
AC compressor doesn’t turn on
Check wiring
Thanks guys.
Problems:
Power steering leak
Front left cv leak
front tires rub
Roll front fenders
Replace UCA
CEL from pcv leak
Check wiring
Thanks guys.
