Problems, need help!
Been having a few problems with my car recently. Since i've had the car i have noticed a small tick only ocasionally but in the past 2 months it's gotten a little worst, haven't noticed it in about two weeks, it has been doin well, but at times when stoped or in neutral it sounds almost like a diesel. If i rev the engine it goes away but then drops to idle and it comes back. So i thought maybe the engine was dirty and the valves were not the cleanest, so i threw a can of 44K in the car. I did that today so i haven't given it time to see if it helps. But i did some research and it seems like it could be the cam tensioner, or i read that something about it could be simple as i believe it was power stearing being low. Does those two problems sound right?
Another problem this has only happened a couple times but when i start the car it would give me a really loud whining noice, when i pop the hood it got even louder. i read that it could be a bad fuel filter. does that sound right?
any advice would be great, also how much would all this cost me to do myself if those are the problems. i also read that maybe some seafoam would help out.
Um the loud whining almost sounds like a belt? wheres the noise coming from? and I would do an oil change sea foam and throw some motor honey in it. Theres also something near the airbox that develops a tick and is normal. Does the tick sound like its coming from the engine? The fact that the ticking goes away under accelaration makes me wanna say its not the cam tensioner
edit: if you're gonna do it yourself Auditech79 put a cam chain DIY up in the DIY section.
sounds like you have a couple of problems. 1st check your power steering fluid sounds like you are a little low. Then you noisy engine could be the timing chain tensioner or a sludged up engine. Take a screwdriver and put the handle to your ear and touch the other end on different parts of the engine. Where it is the loudest is the location of your problem. If its coming from the back of the engine then it probably the chain tensioner. If the noise is coming from all over then i would say a sludged up engine. good luck
