problems with audi???
i went a got a new scanner and ran it and it came up with the code p1545 what should i do? the guy told me he already cleaned out the throttle body and its still doin the same idle problem. they checked all the vaccum hoses and said they were fine, do u think i need to replace the whole throttle body? and we also changed the maf sensor also
i got the vag com cable off ebay now i need to download the program... which one do i need? can i do a tba with the free one or do i have to buy the program, if i have to buy it can someone give me the direct link to the one i have to buy because im not sure which one to get
#18
i just took the car to a real shop and the guy told me i have to put a headunit in it cause the communication is gettin messed up,, my question is my friend has a 99 vw passat and has his stock radio just sitting around. will the fit in my car? if not will a aftermarket headunit work?
#19
il say this again because you apparently missed it
some aftermarket radios seem to work, some dont. theres no rhyme or reason to it really. the passat radio might fit, no harm in trying. i would guess that it wont though. if the connectors are the same on the back of the radio then it should work.
#20
so if the one from the passat doesnt work what should i do? i have an aftermarket i can try but i hope it works. and one more question.. with the headunit not in can i still due a tba or not having a radio in screw everything up? and i called audi today and they said i didnt need a radio to do anything but i guess they were just bullshitting
