Priming my turbo
Old 08-12-2010 | 09:00 PM
Mike-2ptzero's Avatar
You didn't even need to do that since oil has already be used on the turbo before it was boxed up.
No different then when you leave the car parked over night and all the oil has drained out of the turbo.
Old 08-12-2010 | 09:21 PM
FASTER's Avatar
Tech Slut
I think he just installed a new k04, no?
Old 08-12-2010 | 09:33 PM
Doesn't matter if it is brand new, every single turbo is spun at a high rate before it is boxed up to make sure the turbo is fully balanced. When you pull the turbo out of the box it should have caps/plugs on the oil/coolant openings to keep the oil residue from dripping out and to keep dust out.
Old 08-12-2010 | 09:56 PM
FASTER's Avatar
Tech Slut
Well I guess you learn something new everyday. Im still over cautious with stuff I spend alot of money on tho.
Old 08-12-2010 | 10:05 PM
If that is the case then all you have to do is drip a few drops into the oil feed hole in the turbo before you put the line on.
Old 08-13-2010 | 12:46 AM
joenelson7687's Avatar
It wasnt a new k04, btw. Well I finally took it out tonight and it went just ok...I have a boostleak somewhere so I'll be spending tomorrow looking for it. God only knows where this one(s) could be, but it was to be expected. I do have a weird question. The EGR valve thats on the back on the motor...if I get the block off plate for it, is there anything else I need to do besides that? I don't have a secondary air pump anyway.
Old 08-13-2010 | 01:34 AM
If you dont have a pump then you dont need anything else. If you need one I have a bunch of the IE block off plates.
  #18
Old 08-13-2010 | 07:49 AM
I could DEFINETLY use one. Be nice not to have the stuff cluttering my pretty engine bay
Peteyac
08-02-2015 11:22 AM
Big_Jerm_210
06-25-2014 03:39 AM
Quick Reply: Priming my turbo
