power steering pump help
Old 12-15-2009, 11:21 AM
dragonrage's Avatar
The JB Weld might work for now but I wouldn't count on it long term. If you search Ebay for "power steering cooler" then there are lots of them for under $10. Or you could just buy some line of the correct size as ITD suggested. Also, for clamps, make sure to use really high quality ones. I would prefer T-bolt clamps. Power steering lines can be under a lot of pressure. Don't screw around with them.
And, you know, you can put certain forum members on ignore.
  #22
Old 12-15-2009, 12:15 PM
flynnr's Avatar
yeah, that pressure is sure to burst that jb weld within a month or two... just do it right and buy that tubing and bend it similarly to what yours is... i bet it can be done for under $15 total... its going to blow again and you are going to end up spending another $50 to tow it....
  #23
Old 12-15-2009, 04:37 PM
Mr. Phil's Avatar
well it only needs to last for about a month anyways, cuz im getting my financial aid and im just gonna replace it
  #24
Old 12-15-2009, 05:46 PM
dragonrage's Avatar
Good luck...
  #25
Old 12-15-2009, 07:14 PM
Beer Mod's Avatar
Originally Posted by dragonrage
The JB Weld might work for now but I wouldn't count on it long term. If you search Ebay for "power steering cooler" Power steering lines can be under a lot of pressure.
Just so you know Phil, coolers are never on the pressure side of any power steering system. The high pressure side of a steering system can reach into the 1,000psi and up range. Low pressure side has little to no pressure at all, your fine for a month or two till you get money.
xDABSx
03-29-2012 09:26 AM
morto
06-04-2010 12:46 PM
SPhilli911
01-31-2009 12:49 AM
pimptrooper3000
01-01-2008 12:39 PM
Quick Reply: power steering pump help
