PLZ! Need Help! 01 a4 1.8t in 97 a4 1.8t???
What do I need to change, internal water pump on 01 and external water pump on 97, are the valve covers inter changeable???? Im stuck. I threw a rod in the 97 and I have an 01 motor, whats needed?
so... no?
Wel I already have the engine, im assuming its not going to be too easy but is it possible with switching stuff around or is it going to need a bunch of custom brackets, etc that wont make it worth it? They look almost identical
there are updates/upgrades on the awm block compared to the aeb block, so you would need to get an 01 ecu as well..... but then it won't run your instrument cluster right, so long story short, sell the awm block and get another aeb block
there is an aeb short block for 150
but if you can make it work i'd take the aeb head off your hands
Well im switching all the sensors to the AEB ones. I guess this weeekend ill know. As long as it bolts up to the tranny I will see if it starts. Why would I need to use the other ecu? It doesnt plug in...? Also if it does work I will have the AEB long block for sale.
