Please HELP identify oil leak -PICS!
Old 01-29-2011, 02:21 AM
FASTER's Avatar
Tech Slut
Originally Posted by Keegan0103
It almost looks like the turbo oil drain line, or the sensor on the pan,
Cant tell though
oil return is on the passenger side, and the sensor (if its a 1.8 with one) would be below that point.
Originally Posted by Aud1A4
I dont feel like solving the problem at the moment as its "not a major problem"
but since its leaking oil....
Should I add more oil into the engine?
Should I get more frequent oil change?
If you don't feel like solving it then why are you making a thread about it?
Check the oil level more often and top off as needed, but no need to shorten the interval between changes.
Old 01-29-2011, 02:24 AM
hiwords's Avatar
it looks like the leak is near the subframe. half moon seal? check your oil level first. if it needs oil, add some. if not, leave it alone and get some better pix from up top too
deem2000
05-10-2012 12:46 PM
riydan
09-03-2010 07:45 AM
mypreludeisred
01-02-2008 03:05 PM
loustylez
11-12-2007 01:47 AM
jwellyman
11-13-2006 02:17 PM
Quick Reply: Please HELP identify oil leak -PICS!
