performance intake manifolds
RE: performance intake manifolds
if you have the AEB manifold, i don't think they make a better flowing one then that. I know a lot of AWM (2001) guys put in the AEB head and manifold to produce more air into the engine with there bt upgrades.
i could be completely wrong and i myself am unaware of companies that make a better intake manifold for our car.
what you guys dont understand...is that my mod i have now are nothing compared to the ones going in in a month
im going BT
so im thinking of porting and polishing it and also gasket matching it with the big port 10mm thick gasket....what do you think?
im going BT
ORIGINAL: 1.8TK3MP
im going BT
im going BT
if you port and polish it, you may as well put in a phenolic gasket since you already have the manifold off. I am putting my evoheatshield (phenolic gasket) in this friday, so i can let u know how it goes.
if you get that tuner thing working properly, u might want to consider getting a w/m kit, that way u have cooler temps and u can adjust the timing for more hp. just a thought.
http://www.evolutiontuning.com/evohe...HC20Vlarge.htm
thats the one for your engine, you do have the big port right?
this is what im installing on my car, it is .250" thick, whatever that equals in mm i don't know
034 and New South Performance also make a gaskets you can look into.
