Passenger side fogs out
Noticed that the front passenger side fog light was out, so I went and got a replacement bulb and swapped it out. But alas, the light is still not turning on.
Then I noticed that the rear fog on the passenger side was out as well.
Anyone know what could be causing this? And what I can do to fix it?
there's no bulb in the passenger rear fog light. take out the bulb holder and you'll see what i mean. get a multimeter and see if you get power to the harness at the light in the front. also are there any corrosion on the fog lights?
If you have a bulb in the rear fog on the passenger side, then the prior owner did the dual rear fog mod. Like Hiwords said, check for corrosion or broken wires, etc - you may have a problem that way.
You need to go to your member page and create a signature that includes year, model, engine, transmission, and drive setup so we can help answer future questions more easily. There are a huge number of changes that were made throughout the life of these cars and having to ask every time what you drive is going to grate on people.
chawkinson
04-28-2017 07:49 PM
mr_indomitable
04-23-2009 11:06 PM
