Passat AEB Samco hose kit fit an AEB A4?
Well title says it all, Will a Samco hose kit that came off a 99 1.8T AEB passat fit the same as a 1.8T AEB A4?
Talking the hoses from:
Turbo to front tube
Hose to DV
Hose from front tube to SMIC
TBB
Turbo to front tube
Hose to DV
TBB
It'll work. But if its a 97 AEB, the dv/intake plumbing is slightly different and with the samco kit the dv would be relocated down towards the bottom like all 98+ 1.8Ts. It's not a problem, I'm just saying.
Spotted this set on eBay. HERE and as you can see the auction title says it would work for 97-00 1.8T AEB A4's.
Vividracing.com has a another used set for $100
http://www.vividracing.com/catalog/s...c-p-53065.html
I'll get the set I purchased on Tuesday, then I'll be able to compare the hoses with the one's that I can see. It's -20 below out right now, so don't plan on installing them still it gets a bit warmer out.
Are you getting the same kit? Can you let me know if everything works out?
